Need a suggestion
Old Oct 10, 2007 | 12:56 AM
joshfromcomo's Avatar
Need a suggestion
i have a 1984 Z28 Camaro with a 327 vette motor. and sumbody stole a distributor out of the motor. and the battery is no good. so im prolly gonna need to replace both of them, plus the altonator. wat i want to kno is about wat am i lookin' on spending on parts and labor.
Old Oct 10, 2007 | 01:36 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: Need a suggestion
Parts wise....150-the sky is the limit on performance and aftermarket. Labor is free if you do it yourself.
Old Oct 11, 2007 | 03:23 AM
well how much for labor included? im not much of a mechanic. =)
Old Oct 11, 2007 | 10:08 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
"327 vette motor" - scary words.
If the engine was replaced using the original equipment to run it, not too bad. But, I would guess that isn't the case, since the last 327 put in a Vette didn't have the accessory holes in the front of the heads to mount '84 Camaro alternator, PS pump, AC, etc. Meaning this was probably a real hack job. Or whoever told you it has a "327 vette motor" is an out-&-out liar.
You'll have to have shops in your area look at it and give you estimates. Since the car can't be driven there, you've got quite a task on your hands.
darwinprice
17
Oct 11, 2015 11:51 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
gord327
Oct 3, 2015 01:25 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
R13_Braz
Sep 18, 2015 05:00 PM
