Diagnostic Port Tuner?
Old Oct 12, 2007 | 08:50 AM
Roadkid91's Avatar
Car: 1987 Trans Am
Engine: LB9
Hey, does anyone know of a thing that would plug into the diagnostic port of a 1987 Trans Am that would allow for tuning? Thanks.
Old Oct 12, 2007 | 10:03 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Diagnostic Port Tuner?
OBD-1 usb cable from moates.net will allow you to scan the computer. A prom burner and adaptor along with Tuner-Pro will allow you to tune. See stickies on the DIY-Prom board.
Old Oct 12, 2007 | 01:05 PM
Roadkid91's Avatar
Car: 1987 Trans Am
Engine: LB9
Ok thanks man.
Anyone else have anything?
Old Oct 12, 2007 | 02:18 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
If you get an ostrich (moates) you can tune in real time....
Use tunerpro to do it.
Old Oct 14, 2007 | 01:10 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
No, there is nothing that allows you to make changes thru the ALDL connector. You need to drop the computer and change the prom. You can use the Moates Ostrich to make changes on the fly using a laptop, but that ties directly into the computer, not the ALDL.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sammy52401
Nov 11, 2015 07:20 PM
tmellott89
Oct 14, 2015 02:06 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bplessy
Sep 30, 2015 12:14 PM
