305 TPI, if I remove the AC compressor, which belt PN?
Old Oct 12, 2007 | 11:13 PM
DREGSZ's Avatar
305 TPI, if I remove the AC compressor, which belt PN should I use??
Evan
Old Oct 14, 2007 | 09:47 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: 305 TPI, if I remove the AC compressor, which belt PN?
Take a piece of string take it around all the pulleys, and then measure how long it is. It's the easiest way
Old Oct 14, 2007 | 10:59 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If you want to remove the A/C, you MUST use an A/C delete pulley. There is no other easy way I know of. You can use the same stock belt that way.
Old Oct 15, 2007 | 01:45 AM
DREGSZ's Avatar
Where might I find an A/C delete pulley?
It seems like that might be an uncommon item
THanks
Evan
Old Oct 15, 2007 | 02:03 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Advance Auto Parts has 2 Delete Pulleys:
http://www.partsamerica.com/ProductD...pe=395&PTSet=A
Dorman Air Conditioning Bypass Pulley
Part Number: 34157
$22.99
Motormite AC BYPASS PULLEY
Part Number: 34157
$29.88
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
