What Torque To use on oil and Tranmission pans?
Old Oct 14, 2007 | 08:03 AM
PROPHET69's Avatar
Car: Modified 1985 Z28
Engine: 355 Carbureted
Transmission: TH350 Turbo
Hi people. I'm going to be re-installing my oil and transmission pan with new seals. I know, that the screws around the pans are very lightly. I have an inch-pounds torque wrench, anyone know how much torque i should use on each one? Oh, and should i use some sort of a seal on each screw?
Old Oct 14, 2007 | 08:40 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Re: What Torque To use on oil and Tranmission pans?
Engine Oil Pan- Stud 5/16-18x.44 10 in.lbs. minimum. Stud Nut 9-11 N.m,150-180 in.lbs. 1/4 20x.56-4-5 N.m 72-90 in.lbs. Stud 1/4-20x.50x.56 4-5 N.m, 72-90 in.lbs. Transmission Pan-1.25x19.3 11 N.m (8 ft. lbs.) All specs per GM Chevy Camaro Service Manual P.S. Use the Fel-Pro Blue Re-useable engine oil pan gasket kit. Comes with new pan bolts with star washers. Uses no sealant or glue and does not leak. Has installation guide pins to hold it up. If you already have a pan gasket, adhere it to the pan, not the block. Use a pliable silicone like Permatex, same for the tranny pan. Always glue gasket to cover, not block or transmission case.
Old Oct 14, 2007 | 09:19 AM
PROPHET69's Avatar
Ah! wicked stuff! thanks!
Hotrodboba400
Dec 10, 2019 07:07 PM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
