416 vs 350 vortec heads--305
Old Oct 17, 2007 | 01:36 PM
Tim Hunsinger's Avatar
Car: 91 RS,
Engine: 406ci
Axle/Gears: 2.77 9 bolt
Quick question. I need to rebuild my 416 heads for a 305 motor that sees 2500-4500 rpm. I have a set of fresh 350 vortecs 1.92/1.5" valves with intake that I may use instead. Which would flow better? The 416's have same size valves, but otherwise stock (I think). My concern is the compression drop with using 64cc Vortecs on a 305. The 416's are 58cc and the cam is mild .400 lift. thanks for any input.
Old Oct 17, 2007 | 05:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The Vortecs will flow a little better, and will probably make up the loss from the lower compression.
I assume 1.9" intake valves were installed in the 416's at some time.
Old Oct 18, 2007 | 05:37 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
Re: 416 vs 350 vortec heads--305
350 heads on a 305 is a big mistake man.....
Old Oct 18, 2007 | 07:01 PM
five7kid's Avatar
Depends upon which 350 heads. In this case, it is not a "big mistake".
Old Oct 18, 2007 | 10:22 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Not the Vortecs, especially if you mill the heads some and use the Felpro rubber embossed steel shim headgasket (4.100 x .016" compressed). Not even milling the heads, you will still be around 9:1 with the Felpro head gaskets.
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Stryker412
Sep 7, 2015 09:11 AM
85Special
Sep 3, 2015 04:21 PM
Formula_88AE
Sep 3, 2015 01:47 PM
