I have low vacuum now, and am about to buy pump for brakes... Cam and intake Q
Old Oct 17, 2007 | 02:47 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Ok, well i am running a cam right now that makes pretty low vacuum. Like 8". It is in a street car. I drive it to work everyday and I think I am having brake issues due to the low vacuum. If I buy a pump, can I change my cam for something even more nuts since I don't need to worry about vacuum anymore? I want some good low end TQ. I make pretty good power around 350/350 TQ at the wheels. Wondering if I get a different intake and cam, could I make more...
I want to get the pump for the brakes cuz I can only assume that vacuum will go down not up with more power...
I found one that pulls 26" and only cost $150. Should I get it???
Sorry for the broad Q, but if I said all the specifics, no one would read though it all.
Thanks for any help.
Old Oct 17, 2007 | 03:23 PM
avengersteve's Avatar
Car: 1988 firbird formula
Engine: 5.7l pony eater
Axle/Gears: 4.10
Re: I have low vacuum now, and am about to buy pump for brakes... Cam and intake Q
here is what i would do, get the pump, see if your whole car can run w/o engine vac.. if it can go nuts
Old Oct 17, 2007 | 04:37 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
if you are looking for low end TQ for street driving i wouldnt go any bigger with the cam... might go smaller... the bigger cam will move the TQ and HP further into the RPMS
Old Oct 17, 2007 | 05:23 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I'd just look at a vacuum can, rather than a vacuum pump. $30, and they work great from what i've heard.
But yea, bigger cam would kill your low end, if you like it now, I wouldn't change to a bigger cam.
Old Oct 18, 2007 | 07:53 AM
Engine: LS3
I have a vac canister. Not enough.
I am thinking about going with a smaller cam. And changing my intake.
Going with a dual plane. Air-gap. and then getting a smaller cam to move the TQ down to where I can use it. Then drive the crap out of it till I get out of school, then toss some boost on her.
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
italiano67
Dec 11, 2016 09:21 AM
TreDeClaw
Aug 14, 2015 06:58 PM
Street Lethal
Aug 12, 2015 11:33 AM
