NO SPARK PLEASE HELP!!
Old Oct 18, 2007 | 11:25 PM
PPM's Avatar
PPM
Car: 1991 Chevrolet Camaro Z28
Transmission: Tremac T-56 6 Speed
Axle/Gears: 10 Bolt 3.73 POSI
I have the msd 6AL box and there is power and signal to the box and ignition module, but there is no power coming out of the box to the coil. HELP PLEASE!!
Old Oct 19, 2007 | 08:39 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: NO SPARK PLEASE HELP!!
I'm not trying to be a jerk but I'm not sure how anyone is suppose to help you. You do not list what kind of car it is, motor, tranny, rear-end, mods, etc. Not to mention that no one has any clue how you have wired your 6AL box.
Old Oct 19, 2007 | 10:59 PM
PPM's Avatar
PPM
First off it is a 91 Z28 5.7.
Second i dont mean to be a jerk but is there any other way then on to mount and msd box but to the ignition and why do you need to know the tranny, rear end mods? it has noithing to do with the motor and ign no start problem.
Today i tested it and i got: power to the msd box, no power to the igniton modul, no power to the coil.
Old Oct 20, 2007 | 02:09 PM
GFR88IROCZ's Avatar
Car: 86 Sport Coupe
Engine: LG4
Transmission: BW 5 speed
Are you trying to use an MSD harness. Check the red wires for continutity. I purchased one and it was bad, got a replacement and it too was defective. finally cut into my factory harness and wired it like the book said. Bingo! everything worked. Hope this helps DJ
Old Nov 12, 2007 | 08:01 PM
PPM's Avatar
PPM
Today i testeed it again there is no power to the ignition module, then no power to the coil and power the msd box.
anyone know possible reason why?
Could it be the computer?
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
