RPM issue
Old Oct 19, 2007 | 10:30 AM
JRods Firebird's Avatar
Car: Different Rides but 1991 Firebird
Engine: V6 3.1 in Bird
RPM issue
Well that past wk Ive been noticing some issues while coming to a stop. For 20 miles per hour and down the RPM with go to 500 then on its own go to 1000 without me touching the gas pedal. Its very weried and Ive been trying to restore the car for a month now and Im having good success but this RPM issue has got me puzzled. Ive been checking for a vac leak and fixed 2 of them and even some exposed wires that went to the throttle body but any ideas would be great. Thanks
Old Oct 19, 2007 | 01:45 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: RPM issue
Do you get any trouble codes? does your check engine light light up when you first start the car? (or is it burned out?)
Vacuum leaks are one of few problems that won't throw a code. You can use an unlit propane bottle to help search for vacuum leaks. The extra fuel will kick up the idle speed.
Otherwise, check throttle position sensor, idle air control valve, etc.
Old Oct 19, 2007 | 01:57 PM
Re: RPM issue
No codes at all. It does work. Even when 3 wires were exposed to each other and I have no clue why that was like that and I cant believe it didnt throw a code there. Im mostly back road driving around 55 and drives great. Great gas mileage. Im waiting on a repair manuel I got on ebay to get more of an idea on this engine. Im not to familiar with it with this 3.1 engine. Can those sensor be cleaned out.
Old Oct 19, 2007 | 04:07 PM
Re: RPM issue
Just went down to the local Midas shop and was hereing some noises underneath the car and they said its a bad converter which is making the noise but can it also cause my RPM issue that Im having. What do you guys think
Old Oct 19, 2007 | 04:33 PM
Sonix's Avatar
Car: 1982 Trans-Am
Re: RPM issue
I'm very untrusting of guys working in brake/muffler shops. They know brakes, and mufflers, aside from that i'm leery.
It very well could be that though. I'm no expert on V6's, auto trannys, or FI though, so I'll back out of this thread....
Old Oct 19, 2007 | 05:27 PM
Re: RPM issue
well that makes 2 of us
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
Cornholio7979
Sep 20, 2018 02:31 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
