studs are damaged help
Old Oct 19, 2007 | 10:48 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
i went and took off my rear tire and notice that one stud that you screw your lug nutz on is damaged. what i mean by damage is the threads on it are bent. I there a way to fix this?
Old Oct 19, 2007 | 11:28 PM
Pocket's Avatar
Car: 91 Trans Am
Re: studs are damaged help
Go to a tire shop and tell them to replace the stud
Old Oct 20, 2007 | 12:45 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Might be able to use a thread file on it, but if they're beyond repair, you can get someone to replace it.
Old Oct 21, 2007 | 01:11 PM
92RSsleeper's Avatar
Car: 92 Camaro
Engine: 404 SBC
Transmission: The strongest stock T5 ever made
Axle/Gears: 3.73 w/Detriot Tru Trac Locker
just go to auto zone or something and buy a new stud, theyre like $1.50 and hammer out the old stud, then over tighten the stud and the nut with an air gun so the stud will stay in place when you put the tire on - 10 minute job
Old Oct 21, 2007 | 04:42 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
that might work for a front tire with disk brakes... but not on a axle.... the rear end will need to be opened up.... it is best to have a shop do it if you are already calling things "lug nutz"
no green
Jan 9, 2016 09:22 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
TheCardinal
Interior Parts Wanted
Oct 9, 2015 09:43 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
