centerbolt cover leaks
Old Oct 22, 2007 | 12:46 AM
tak0064's Avatar
Car: 1990 formula 305 tbi
Engine: 305 tbi
i've searched around for a bit, and found quite a bit of info on leaky valve covers, but none of them answered my questions.
my stock valvecovers are leaking oil out of the 4 bolt holes on the top of both of them, as well as out of the oil cap. They aren't leaking at all around the perimeters of the covers though. I have tightened all of the bolts on top, got a new pcv valve, as well as a new oil cap, but it hasn't stopped it from leaking at all.
i feel like this is a very easy fix, but i am clueless.....does anyone know what could be causing this?
Old Oct 22, 2007 | 01:09 AM
chevyboy's Avatar
Car: 1990 RS
Engine: Mild 396 Smallblock
Transmission: TCI Streetfighter turbo 350
Axle/Gears: 3.73 10 bolt Strange Posi
Re: centerbolt cover leaks
Have you tried using an O-ring on your four hold down bolts? I used that trick before I switched to perimiter bolt aluminums.
Old Oct 22, 2007 | 01:21 PM
tak0064's Avatar
Engine: 305 tbi
i haven't tried o rings yet, but that definitely makes sense. what would i do about my oil cap leaking as well?
Old Oct 23, 2007 | 07:05 PM
tak0064's Avatar
Engine: 305 tbi
i set up a second pcv valve on the passenger side so that there would be one on both sides, and made both pcv lines run to a T connector in front of the tb, so far the leaks have gone away.
Old Oct 23, 2007 | 07:18 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
okay now you should take out the second PCV and put the breather back in... and use a little RTV around the bolt heads and install that new "working" PCV on the driverside... that way you have 1 functioning PCV and 1 functioning breather....
NOT 2 of either
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
355tpipickup
Sep 13, 2015 11:35 PM
tgp1990
Sep 4, 2015 06:24 AM
