new fuel pump wont run any ideas
Old Oct 22, 2007 | 03:05 PM
rad russ's Avatar
Car: 1987 IROC Z
Engine: 5.7
I have replaced my fuel pump in my 87 iroc 5.7 If i run a wire from the g terminal on the on board diag. to 12 volts relay kicks in but no fuel pump. could I have a bad ecm or maybe hahaha it is a bad fuel pump again. If the ecm is bad how can I tell? Plus I have gotten no trouble codes. Any suggestions or Ideas would be greatly apperiated. plus the fuel gauge is not working, It registers 3/4 turn the key on and it goes to full with no gas in the tank Does anyone think it might be a bad sending unit? I 've had the tank filled with fuel for 5 months before this problem started. It did run with the previous fuel pump. and a one point when jumped to termianal g it did clunk when it tried to run. Can the pumps just go bad from sitting even if it was a brand new pump?
Old Oct 22, 2007 | 06:02 PM
86z28305's Avatar
Car: 1986 Chevrolet Camaro Z28/99 Aurora
Engine: LB9 5.0 TPI/4.0 V8
Transmission: 700r4/?
Axle/Gears: 2.73/3.08
Re: new fuel pump wont run any ideas
I had a problem kind of like that, I didnt realize on my 86 that the fuel pump fuse was under the hood next to the battery, have you checked this?
Old Oct 22, 2007 | 07:05 PM
rad russ's Avatar
Car: 1987 IROC Z
Engine: 5.7
yes it is good and i even replaced it to be sure.
Old Oct 23, 2007 | 09:34 PM
LORDCRETH's Avatar
Car: 1998 Corvette Conv.
Engine: 5.7l
Transmission: 6-speed
I'd suspect the pump itself. Try wiring the pump directly to 12v and see if it works. Strange that a new pump would be bad, though.
Old Oct 24, 2007 | 07:42 PM
rad russ's Avatar
Car: 1987 IROC Z
Engine: 5.7
PULL SENDING UNIT POUT TANK HAD KUST BEEN FLUSHED AND DRIED . SAT FOR A 5 MONTH PERIOD. JUST PULL OUT SENDING UNIT, LOOK LIKE#@#@#, ALL RUSTED i'M GLAD TO SEE THAT THE GAS WE PAY SO MUCH FOR IS JUNK, LOTS OF WATER. SHELL GAS BP GAS IS ALL i EVER USED. KILL'EM ALL LET GOD SORT'EM OUT.
Old Oct 26, 2007 | 11:49 AM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
I had the same problem on my 91 after replacing the fuel pump in the tank. I was worried when it didn't work after all that work. Then I changed the fuel pump relay and bam it works great. You may want to check the relay if you haven't yet.
Old Oct 26, 2007 | 12:27 PM
backgammon7's Avatar
Car: '86 SC
Engine: 2.8
86z28305, my fuel pump is shot to, would the fuse be there on a v6 to?
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
