fuel pressure question
Old Oct 23, 2007 | 05:02 PM
rad russ's Avatar
Car: 1987 IROC Z
Engine: 5.7
I have a bbk adjustable pressure regulator and I was surious the stock reg ran at 36-37 psi. With the new reg can I get more pressure than this with a stock pump tpi 5.7
Old Oct 23, 2007 | 06:07 PM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
Re: fuel pressure question
Yes. But if you're going to start upgrading your engine for power, you need to upgrade your pump too.
Old Oct 23, 2007 | 06:10 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
you should be running around 40 PSI 36 is to low
Old Oct 23, 2007 | 06:16 PM
rad russ's Avatar
Car: 1987 IROC Z
Engine: 5.7
what do you think would be causing it to run at 36 or 37 verses the 40 you say?
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
