Head Ports Size
Old Oct 24, 2007 | 11:31 AM
mlaudon's Avatar
Car: 89 Camaro Rs
Engine: 355 build up
Transmission: TH350
Head Ports Size
Well im building my engine and i almost have enough money for some aluminum heads. But i dont know what size to go with? i know the valves are going to be 2.02"/1.60". With a 64cc Combustion Chambers. So should i put some 190cc intake or some 210cc intake on.
The engine is a 350 .o30 over 355 10.1 comp w/ 64cc heads.
Stock rods.
Stock crank.
Cam is a 480/480 lift.Hydraulic Lifters
Heads are going to have 1.6 roller rockers.
Dont know about intake yet.
th350 with a 3300 stall. auto
Tell me what you think of the set up?
Old Oct 24, 2007 | 11:48 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Head Ports Size
Cam is to small on the lift. For the heads 180, 190, 195 or 200cc intake runners will do the trick. I would not go over 200cc on a built 355.
Old Oct 24, 2007 | 02:11 PM
mlaudon's Avatar
Car: 89 Camaro Rs
Transmission: TH350
Re: Head Ports Size
what size cam should i use then cuz with the i mesed up the cam is a 512/512 lift
Old Oct 24, 2007 | 02:33 PM
Re: Head Ports Size
Looks like the cam is the same (the old 280 Magnum it looks like); you just have 1.6 rockers.
Try to get chambers smaller than 64cc, if you don't have pinging problems now. With aluminum heads you need close to a full point higher CR to get the same cyl pressure (power output) as iron heads.
Old Oct 24, 2007 | 02:47 PM
mlaudon's Avatar
Car: 89 Camaro Rs
Transmission: TH350
Re: Head Ports Size
So your saying if i want 10.1 CR i would have to go with a 62cc or a 60cc to get 10.1 CR. Im just dont know what size heads i should go with to gewt some good hp.
Old Oct 29, 2007 | 09:07 PM
Travis&camaro's Avatar
Car: 1984 Camaro
Engine: BIG BAD 360!!!!
Transmission: th350 shift kit 3600 stall
Axle/Gears: 3:73 posi
Re: Head Ports Size
Nice set up.. But I would go with 4valve after market aluminum heads if you can get the money. It would make a sweet *** engine.
Old Oct 29, 2007 | 09:24 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
Re: Head Ports Size
I think a 195cc intake runner is perfect for a street/strip 350. My preferance would be Trickflow or AFR.
Bad idea. It's seriously NOT worth the hassle, not to mention the MASSIVE price of a set of such heads.
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
NinjaNife
Aug 23, 2015 11:49 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
knight72
Aug 10, 2015 09:32 PM
