Trick Flow heads
Old Oct 29, 2007 | 11:42 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Trick Flow heads
http://www.trickflow.com/product/che...3degree175.asp
Anybody have any experience with these heads? Specifically, whether or not they have an exhaust crossover so I can keep my EGR? I emailed then called Trick Flow and got conflicting answers. Also, for my application, a 305 TPI, (Save it. I'm not going 350/383 at this point in time. ), my choices are these or World Products S/R's. From what I've been able to find out so far, the Trick Flows flow much better and would have the weight saving advantage of aluminum, compression advantage notwithstanding. Yes? No? Why? Thanks!
Old Oct 29, 2007 | 12:28 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Trick Flow heads
Yes they do. I ran them on my car with the EGR. Can't remember if they had to be drilled to activate the exhaust gas crossover or not. I know it had to be done on the Darts I'm now using. But the bottom line is yes.
Update. I just checked the picture in the link and the hole is there for the egr.
Old Oct 29, 2007 | 02:16 PM
watajob's Avatar
Car: 92 T/A 'vert
Great. Thanks for the info!
Old Oct 29, 2007 | 11:28 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Wait and save your money and go 350/383, sorry just my .02
gta90
Sep 15, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Ducati900ss
Sep 2, 2015 09:05 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
