Midwest motorsports valve springs, anyone know if they are any good?
Old Oct 25, 2007 | 01:16 PM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
Hi, I just found a set of valve springs on ebay. link: http://cgi.ebay.ca/550-Lift-Valve-Sp...QQcmdZViewItem
Some of the specs are:
Seat pressure 110 lbs @ 1.750"
Open pressure 325lbs @ 1.200"
Coil Bind 1.150"
Max lift .550"
They are stock 1.250" diameter.
The price for these is only $42.00 for a set of 16.
Has anyone had any experience with these. Or do you think they would work ok with a cc305 cam?
The cam has a max lift of .510 with 1.5 rockers or .544 with 1.6. I haven't decided if I am going with 1.5's or 1.6's. I'm not even sure if i can get .544 lift with the factory 1990 l98 heads. The heads will have some work done to them including screw in studs.
Thanks,
Jamie.
Old Oct 25, 2007 | 02:18 PM
Re: Midwest motorsports valve springs, anyone know if they are any good?
That's a Pioneer part #.
Basically stock replacement.
They are not enough spring for an aggressive aftermarket cam like that.
Yes you can easily get .550 lift on a set of stock heads, with the right work done to them.
Since you have to get head work done ANYWAY, just have the spring pockets cut out so you can use the right springs for the cam (986 or 987 - both are about 1.45" OD). Valve springs are the WRONG place to try to cheeep out.
Old Oct 25, 2007 | 02:30 PM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
Ok, thanks for the info.
I was also told that the tpis springs pn 700-132 were also a good drop in spring. If I only used 1.5 rollers.
customblackbird
Aug 15, 2021 10:16 PM
gta90
Sep 15, 2015 04:00 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
89mulletbird
Aug 12, 2015 07:08 PM
