how do you remove surface rust from inside fuel tank???
Old Oct 25, 2007 | 01:31 PM
rad russ's Avatar
Car: 1987 IROC Z
Engine: 5.7
I have a fuel tank that has rust in the tank not bad. but enough to concern me. Mostly surface rust from where it has sat for a while with fuel in it. How can I get this stuff out. ? a good wire brush ?? Any chemicals I can use? What about muradic acid diulited down? Any help would be great. All of the tanks around in the salvage yard look similar.
Old Oct 25, 2007 | 01:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
http://www.imperialrestoration.com/f...ank_sealer.php
Found by Googling "fuel tank rust removal".
Old Oct 25, 2007 | 02:10 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: how do you remove surface rust from inside fuel tank???
kreem
works great on bike tanks. i suppose you could use it on cart tanks as well.
Old Oct 25, 2007 | 03:13 PM
rad russ's Avatar
Car: 1987 IROC Z
Engine: 5.7
Thank you both for you help.
Frozer!!!
Jan 19, 2024 04:55 PM
mustangman65_79
Apr 14, 2017 05:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
3rdgenparts
Aug 8, 2015 07:09 PM
