Help with Idle issues
Old Aug 26, 2007 | 07:00 PM
Raiden's Avatar
My car has been giving me problems for some time now. I work a lot of OT during the summer and I finally got my car put back together. I had an issue where my Z would hardly idle. I removed the injectors from the intake. I charged the fuel rail and I noticed three injectors were leaking. So, I purchased new injectors off of ebay. They did not leak. I also noticed the headers were cracked at the tiny air lines on the top of the header that go to the smog pump. I welded them. I pulled my heads off and had them gone through from the local machine shop. I finally put everything back together. My car does not want to idle unless I bump up my timing to 15deg advced. I have NO CODES. It does not sound right and seems to surge and shake then it somewhat smoothes out. Now, if I open the throttle, the car will not increase the rpms unless I find a sweet spot in the position of the throttle which is about 1/2 throttle. It only gets to about 3500rpms. I've no idea how to chase this gremlin. I have replaced my map sensor, checked my tps which is fine. I replaced my O2 sensor, fuel injectors, plugs, plug wires, cap, rotor and coil.
Thanks for the help in advance.
Old Aug 26, 2007 | 07:09 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
Re: Help with Idle issues
im haveing the same prob with the 89 GTA any help would be nice
Did you change the pickup in the distributor?
Old Aug 26, 2007 | 07:39 PM
Raiden's Avatar
I replaced my ignition module too! My plugs are BLACK and I have a wet non fuel smelling black fluid comming out my exhaust. If I put my hand about 1 foot behind the exhaust pipe, I get tiny splatters of the stuff. I did have some serious fuel injector leakage as my fuel psi would drop from 43 to 0 in a matter of 2 minutes with the old injectors. My new injectors hold 40psi for 15 minutes before the pressure drops off.
H E L P please
Old Aug 26, 2007 | 07:53 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Put a timing light on it and make sure you are getting advance. from the black spatters and rough running it sounds like the timing is very retarded. My guess would be that something in the ignition has a bad connection or bad ground.
Old Aug 26, 2007 | 08:01 PM
Raiden's Avatar
Yea, my car sounds as if the timing will not advance. I've no idea of where or what to do to chase this gremlin. Thanks for the words and advise! Any more thoughts or ideas, Please PLEASE chime in!
Old Aug 27, 2007 | 12:04 AM
GTAfanatic's Avatar
if its retarded would it be running on the rich side? or lean?
Old Aug 27, 2007 | 01:34 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Raiden
Start with basics:
Reset and clean IAC. See https://www.thirdgen.org/tpimod2
Check fuel pressure (what year is your TPI) should be 42 to 48 psi and steady.
Check for vacuum leaks in all the usual places.
Check your EGR - make sure that is not stuck open - that will screw idle up.
Check ignition coil and spark quality. You can get a an in-line tester. A failing ignition coil may cause misfire at higher RPMS.
Check supply voltage to the coil (must be better than 13.2 Volts when idling)
Check dizzy cap for carbon buildup and cross fire.
Re-verify dizzy #1 cylinder post vs. #1 cyl at TDC vs. timing mark.
Get ALDL cable and WinALDL and get some data logs.
I hope this helps
//RF
Old Aug 30, 2007 | 10:50 PM
Raiden's Avatar
Old Aug 31, 2007 | 07:13 PM
Raiden's Avatar
Well,
When it rains it pours, especially here in Seattle! I pulled out my old lap top and what do ya know, it's TU! I purchased some ford svo injectors and there is a mild difference between my old one's and the new ones. The new injectors do not have the recessed groves for the keepers to hold the injectors in the fuel rail. I had a few issues with fuel spilling out and I think I have a vacume leak where the injectors mate with the intake. I don't hear a hiss and no noticible change in my rpm's when I spray carb cleaner on the suspected areas...but then, I"M GETTING A WHOPPING 5 inches of vacume!!!! I just said skrew it, and purchased some new accell 36lb injectors from summit. I hope this is the problem, but i've no idea of why I"m only getting 5 inches of vacume. I lashed my valves hot and put 1/2 turn past zero. Any ideas? No codes either
Old Aug 31, 2007 | 08:04 PM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
thats no good.
im having some idleing problems as well.
i also live on the west area. (vancouver island)
and yes when it rains it pours. and stays lol. so it sucks working on your car with out a garage
with my car. it idles ok. then goes down to like. 400rpm and back to around 1000 for abit and then goes to about 800 or 900 and stays at that normal rpm. and when you wanna drive it.
step on the gas. and it just like dies. no guts. it spudders and boggs out until you get about 3500 - 4000 rmp. then you start picking up speed then go into 2nd. start alllll over again.
are you having the same problem as well? have you tryed driving it?
Old Oct 22, 2007 | 11:08 PM
Raiden's Avatar
Can you beleive it.... PLUGGED CAT!
Old Oct 23, 2007 | 05:28 PM
RFmaster's Avatar
Car: 75 Beast
Hmmm sounds like your 'kitty' had too much. How did you determined that you have a plugged up CAT? (removing is the most obvious)
//RF
Old Oct 24, 2007 | 02:01 PM
atgrissom21's Avatar
sounds like a tp sensor
Old Oct 24, 2007 | 05:08 PM
Raiden's Avatar
Well, after a ton of frustration, I started to look at the problems I found. 3 leaking fuel injectors. I run my tune rich via FMU with my supercharger. I dropped my exahust from the header collector and it idled perfect! At that point, I KNEW what was up! Cut my cats off and I could not even see through them. I never had a cat plug so quickly as mine did! I gutted them, put a piece of pipe in the cat and welded them back up.
RF, Thank you for your help! AND everyone else!!!!!!!!!!
Old Oct 25, 2007 | 03:59 PM
Da Grim Reaper's Avatar
Car: 86 Z28 & 1980 FIREBIRD
Engine: 350 & 454
Transmission: TURBO 400
check you plug wires they might be crossed
Old Oct 25, 2007 | 04:50 PM
Raiden's Avatar
obviously, you have not read the thread.
Problem was resolved, plugged cats......ended up being the last thing I checked
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
bamaboy0323
Sep 3, 2015 06:07 AM
mike_c
Aug 27, 2015 04:32 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
