383 details
Old Oct 28, 2007 | 07:48 PM
Pennocks91ws6's Avatar
Car: 91 formula ws6
Engine: 1 peice roller scat 383 4 BOLT!!
Transmission: 5 speed
383 details
i got my 383 shotblock built, and keep in mind its gonna be mild for now
i want the motor to appear and sound stock , as im gonna say its a stock 5.0 with exhaust and a filter only
anyways, heres what i got
scat nodular crank, scat rods, k.b hyp pistons
my choice of stock 350 heads ported decently, or vortecs (but id have to drill em)
im stuck on the finishing details, im keeping the stock t.p.i for the break in and tune, till i can later get a hsr or somehting
so, injectors, 24 pounders?
adjustible fpr, and what pressure?
cam, stock with 1.6, or lt1 with 1.6?
stock lifters?
(remeber im a newb on a budget and cant afford the tuning stuff yet, and cant tune anyways)
do i change the whole ecu, or just the prom (should i get one of those custom made ones or what?), because i dont want to wash the **** out of my rings, or lean burn a hole in my pistons right off the bat
any other suggestions would be baller,
im getting the long block for 2500 canadian with a 1 year warrenty btw
Old Oct 28, 2007 | 09:19 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
Re: 383 details
why put all that money in bottom end and none in top? vortecs heads and lt1 cam with 1.5 not 1.6 u may have to have head work done
Old Oct 28, 2007 | 09:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Why would you need to do any drilling on Vortec heads? Don't say so you can mount your current intake, because that is the road to disaster.
Fuel pressure is tuning. Start at stock, and work from there.
You need to get PROM burning equipment and do your own tuning. That's the only sane way to spend performance $'s.
Old Oct 28, 2007 | 09:31 PM
intex1982's Avatar
Re: 383 details
use a old set of 416 port them well and thay will be better than any 350 heads besides vortec and u can run ur tpi intake
Old Oct 29, 2007 | 01:42 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 383 details
He'll have old 081's, which yea, he could keep the TPI intake - if the CR isn't too high. Depends on which pistons you use.
Vortecs would be the choice, but you'd need the aftermarket intake right now Or aftermarket wet intake and carb, which is how i'd go.
Old Oct 29, 2007 | 02:45 PM
Car: 91 formula ws6
Re: 383 details
well ill prob go with an hsr, and i dont think they makem for vortec,s plus thats more money right off the bat, anyways, the reason im going god on the bottom end and mild on top, is for the tuning, money and future upgrades
i want the car to run, and not be so intimitaded with tuning that i scrap the hole car, or slap a carb on it
as said, i want the motor to apear and sound stock, if that means keeping the stock tpi and keepin itu nder 3000 rpm for a few months, w.e (although that will be neer impossible)
i dont think a 383 all hotcammed out will be the simplist thing to tune for a newby that doesnt even have the prom burning stuff yet.
so, all i have to do is mondify the 305's prom?
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
Linson
Oct 1, 2015 09:50 PM
