fuel pump problems
Car: 1985 Z28
Engine: TPI 305
Transmission: factory automatic
Axle/Gears: factory
fuel pump problems
i have an 85 Z28 with a 305 TPI. i think my fuel pump is bad. its an electric, in tank pump and when u turn the ignition on no sounds are made and the car wont start. i know most electric fuel pumps make a sound when the ignition is turned on. is there a fuse for the pump and if so where might it be or do i need a new pump? any suggestions?
thanks!
thanks!
Re: fuel pump problems
Yes there is a fuse; I don't know offhand where it is in an 85.
There's also a relay. Between the brake booster and the fender, there are 3 relays. 2 of them are connected with the MAF; 1 is the FP relay. They are all 3 the same. Try swapping them around and see if the FP starts working. If so, go buy one and replace the bad one. I'd say that's more likely than a blown fuse, so start there.
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
There should be a 2 wire weather pack connector mounted to the body right around the battery, unplug it and the fuel pump fuse is inside the connector.
92camaroJoe
Aug 13, 2015 06:07 AM
