fuel pump removal?
Old Oct 31, 2007 | 04:56 AM
bsherrin01's Avatar
Car: 1985 Z28
Engine: TPI 305
Transmission: factory automatic
Axle/Gears: factory
fuel pump removal?
are there any tips or tricks to removing a fuel tank from my car? i have to change the fuel pump and this will be my first time. any suggestions would be greatly apprecieated! i have a 85 Z28 camaro with the wonderful in tank electric fuel pump. thanks!!
Old Oct 31, 2007 | 09:44 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Best way is to follow the book.
Old Oct 31, 2007 | 01:19 PM
Big Dave's Avatar
Car: 1992 RS Heritage
Transmission: TCI 700r4
Re: fuel pump removal?
Jack the rear of the car up as far as possible, remove exhaust, unbolt panhard bar and brace, shocks and sway bar end links. Unbolt brake hose bracket from body. Lower the axle as far as possible. Remove tank. Its tricky, the filler neck is rigid, and the holes it must pass through are small.
Good luck!
Dave
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
