Cam lock plate
Old Nov 5, 2007 | 06:51 AM
kronos's Avatar
Car: 89RS
Engine: Lo3 bored.030 over, 230/480comp cam
Transmission: 700r4 10" converter
Axle/Gears: Stock G80 2.73
Cam lock plate
When switching from a hydraulic roller to a hydraulic flat tappet cam, it isn't necessary to keep the cam lock plate is it? Older style blocks didn't use them correct? Oh yeah it's a roller block lo3.
Old Nov 5, 2007 | 08:39 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Cam lock plate
No, no need for the cam retainer plate. Flat tappet cam probably isn't cut for it either. Note that the pushrods are longer for the flat tappet cam.
RBob.
Old Nov 5, 2007 | 08:43 AM
Re: Cam lock plate
Right.... your motor doesn't have a "lock plate" (goes under the sprocket bolts and has little tabs to bend up around them to keep the bolts from backing out); it has a "retainer plate" (goes between the sprocket and the nose of the cam and bolts to the lock, to positively locate the cam front-to-rear in the block).
When you downgrade your car that way and give up the benefit of the roller cam, neither the timing set nor the cam will accomodate the retainer plate. You won't use it.
Old Nov 5, 2007 | 12:02 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Cam lock plate
I used a flat tappet cam in a roller block and would suggest a cam button for sure
my timing chain made it way to the timming cover
Old Nov 5, 2007 | 12:49 PM
Re: Cam lock plate
Not necessary....
There are probably a hundred million SBCs in the world with flat tappet cams, maybe more, and no cam button; and they seem to get along just fine.
Old Nov 5, 2007 | 02:28 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Re: Cam lock plate
Correct,
Rollers walk, flat tappets and hydros don't. Could get technical as to lobe and roller design, But,
No, you do not need a cam button.
Later
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Fronzizzle
Mar 18, 2019 08:29 PM
Cameeeero
Sep 18, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
