stalls when ripped on and slow down
Old Nov 5, 2007 | 08:31 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
I have an 87 camaro 350 carb (more specs below) that if I rip on it sometimes and slow down fast but not too fast itll stall. I make sure I let it run for 10-15 minutes usually before I drive it also to heat up. Whats the problem?
Old Nov 6, 2007 | 06:11 AM
Damon's Avatar
Re: stalls when ripped on and slow down
Will it start right back up after stalling or do you have to let it sit for a while?
Old Nov 6, 2007 | 09:09 AM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
No it starts right up fine, I'm wondering if it needs to be idled up? Although it seems like its not too low when warm.
Old Nov 6, 2007 | 09:20 AM
scorchmaster's Avatar
Car: 1984 z28
Engine: BBC
Transmission: TH400
I take it you have a manual transmission. Does it stall when you floor it and leave it in gear without touching the brake, or are you braking too? or are you dropping it to neutral?
Old Nov 6, 2007 | 07:14 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
Dropping to neutral and braking
Old Nov 6, 2007 | 11:17 PM
Car: 1984 z28
Engine: BBC
Transmission: TH400
what does your car idle at normally?
Old Nov 6, 2007 | 11:34 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
Tachs not hooked up yet
Old Nov 6, 2007 | 11:39 PM
Car: 1984 z28
Engine: BBC
Transmission: TH400
Raise your idle and check it out, you shouldnt be having that problem with your setup but raising the idle will help.
Old Nov 7, 2007 | 05:03 AM
zipfast's Avatar
Car: 94 9c1 Caprice
Engine: LT1 (3-fity)
Transmission: 4L60E reBUILT
Axle/Gears: 3:08 POSI (out)
I agree just my
Ed1LE
Sep 30, 2018 09:14 AM
HoosierinWA
Oct 7, 2015 10:15 AM
bjpotter
Oct 4, 2015 07:48 PM
Luigytico09
Oct 1, 2015 08:46 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
