Smoke the camaro...
Old Nov 6, 2007 | 09:20 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Smoke the camaro...
88 iroc z28 5.7 350 smokes like no ones business. Smokes a lot when started up then doesn't smoke until reved. video enclosed http://www.youtube.com/watch?v=Gp6darkgCvA
Valve stem seals?
Old Nov 6, 2007 | 09:31 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Smoke the camaro...
Valve stem seals?
That looks more like ring sealing issues than valve seals to me. Have you checked the compression? Sounds like it needs some P/S fluid too. :-)
Old Nov 6, 2007 | 09:33 PM
TheBigJ's Avatar
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
Rings? changed the oil lately? check out your crank ventilation system maybe its just not sealing... happened on mine
Old Nov 6, 2007 | 09:46 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Power steering looks good. I don't know why it's making that noise. I'll check that tomorrow in the daylight. I hope it's not rings that would suck... Might as well do the stem seals before I do the rings though because if the stem seals are the problem it's a lot less work.. this motor has ~100k on it FYI. I'll do a compression test sometime soon.
Oil has been changed very recently. Rings again I'm hoping that it's not that.. but I will do the compression test. How do I test the ventilation system?
OH BY THE WAY: MY CAT IS BURNT UP. so I'm just putting that out there.
Old Nov 7, 2007 | 04:49 PM
TheBigJ's Avatar
Car: 85 Firebird
i was sayin crankcase vent, only because after i replaced the crankcase vent, it stopped smoking (it smoked just a little bit before) I seen a post somewhere... and since the crankcase now had a good suction it helped keep the rings tighter to the cylinder not sure how it works
a cp test would help, HOPEFULLY its only one piston
FormulasOnly
Jul 23, 2018 08:47 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
