noob motor mount question
Old Nov 7, 2007 | 01:45 PM
offsetfactor's Avatar
Car: 89 Camaro RS
Transmission: Turbo 350
alright, i was under my 89 rs, and i noticed on the side of the motor mount that bolts to the chassis, not all 4 bolt holes are being used, where the two bolt holes are closest to the engine (bottom side) only the front bolt hole was used, and i didnt see a hole to even line the mount up with to add the extra bolt that was missing....
now i work at a parts store, and this is my first v8, but ive already found out the hard way that my transmission is a turbo 350 (700r4 filter/gasket didnt fit) and now it looks like my motor mounts are off.
is there a chance i have some crappy engine swapped in there? or do i need to re-do my motor mounts...?
Old Nov 7, 2007 | 01:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: noob motor mount question
There are only 3 bolts on each mount.
Old Nov 7, 2007 | 01:47 PM
Car: 89 Camaro RS
thank you much,.,,
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
redmaroz
Aug 16, 2015 11:40 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
