3.1L Lifters
Car: 91 Camaro TBI 5.0
3.1L Lifters
Hi All ! ! !
Does anyone know what kind of lifters are in the 3.1L 90-92 v6? I want to reuse them when I change my cam if they are Hydraulic Flat Tapplet, but I want to be prepared if they are roller.
One more thing ! ! ! Are the lifters used in this engine the same as the ones in sbc? Would I just be able to by some for sbc and use them on the 3.1l?
Last edited by Excellegions; Nov 8, 2007 at 03:04 PM. Reason: Automerged Doublepost
Re: 3.1L Lifters
AFAIK they are rollers. But I'm not sure, since I know basically nothing about the 6-cyl motors.
No they are not the same as V8.
If they are flat, you ABSOLUTELY CANNOT re-use them. If they are rollers, you can.
Car: check
Engine: check
Transmission: check
Re: 3.1L Lifters
Crazy as it sounds but they are flat tappet hydraulic. The later year engines based on this block did get rollers. So they are available if you want to upgrade. And as the king-of-sofa's posted, you can not reuse them on a different cam. Can re-use on the same cam, but only if they go back onto the same lobe.
RBob.
RBob.
Transmission: 4L80E/4L80E
I know our '92 Lumina 3.1 has flat tappet, but I wasn't sure what all the differences were between f-body and FWD sedan.
Re: 3.1L Lifters
OK, so just buy new lifters then, take all the ifs, ands, or buts out of the equation. I have the PowerMax Hydraulic Lifter Camshaft from crane for the engine, part# 253941 - RPM 1800-5400; Adv. Dur. 272 Init./284 Exh.; Valve Lift .454 Int./.480 Exh.; Lobe Angle 112 deg. Anyone know where I can get a new set of lifters for my engine? Tried Jegs and Summit, they don't have for camaro 2.8/3.1 lifters. Does the cam have to high of a lift for roller lifters? Could I just get some good condition used ones?
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: 3.1L Lifters
RBob.
RBob.
HoosierinWA
Oct 7, 2015 10:15 AM
skinny z
Oct 5, 2015 06:23 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
dimented24x7
Sep 6, 2015 03:51 PM
