HEI question...
Old Nov 10, 2007 | 06:24 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
HEI question...
I'm sure this question has been asked before.
If I were to install a regular vacuum-advance HEI distributor in place of the computer-controlled unit, how would that affect the rest of the computer-controlled components?...
Old Nov 10, 2007 | 07:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
In a bad way.
The computer distributor supplies the engine speed data to the computer. A regular vacuum/mechanical advance distributor doesn't have that capability.
If you put on a distributor or carburetor that's non-computer, you have to put the other piece on as well.
Old Nov 10, 2007 | 07:25 PM
T.L.'s Avatar
Re: HEI question...
What "other piece" is that? If I were to change the dist and carb to non-CC, would the remaining CC systems still function?...
(Thanks for the reply)
Old Nov 10, 2007 | 07:38 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: HEI question...
No, because they would serve no purpose if you did that. The distributor and carb are the only two parts controlled by the ECM.
Old Nov 10, 2007 | 07:49 PM
T.L.'s Avatar
Re: HEI question...
Okay, THAT is what I was wondering about. I didn't know what all was controlled by the ECM. I know the lock-up torque converter is (along with the carb & dist), but aside from that, I have no clue. This is an '83/'84 model...
Old Nov 10, 2007 | 08:28 PM
five7kid's Avatar
The torque converter lock-up function would also be lost. You'd need to supply that in one fashion or another.
Old Nov 10, 2007 | 09:11 PM
1990_RS350's Avatar
Re: HEI question...
How could he supply to lockup function on the torque converter? I was kind of wondering the same thing as this guy.
Old Nov 10, 2007 | 09:15 PM
five7kid's Avatar
There's a tech article linked from the thirdgen.org homepage about hooking up a manual switch. There are kits available from B&M, TCI, Summit/Jegs, etc.
Hooking up an internal 4th gear switch has also been discussed on the Transmission/Drivetrain forum. Should come up in a search of that forum.
Old Nov 10, 2007 | 09:31 PM
1990_RS350's Avatar
Re: HEI question...
thanks alot man, your always a real help!
Old Nov 11, 2007 | 02:45 PM
Air_Adam's Avatar
Re: HEI question...
Lock up converter.... forgot about that - all my cars have been stick cars, so never been an issue for me lol.
Old Nov 11, 2007 | 08:08 PM
T.L.'s Avatar
Re: HEI question...
So is my understanding correct that the ECM controls only 3 things; TCC, Carb, Distributor?...
Old Nov 11, 2007 | 09:51 PM
five7kid's Avatar
It also controls the A.I.R. diverter valve, the EGR valve, and the knock sensor won't operate without the computer (this is an HO, right?).
Are you exempt from emissions testing now?
Old Nov 11, 2007 | 09:55 PM
T.L.'s Avatar
Re: HEI question...
All that, huh?
Yes, it's an "H.O."
And yes, I'm now exempt of emissions testing. I'm really not sure if I should keep everything the way it is, or eliminate all that stuff. I was just kicking ideas around...
Old Nov 11, 2007 | 10:06 PM
five7kid's Avatar
My opinion is that you have to have a very good reason to remove the computer system. If you have a manual transmission, that's one reason. If you exclusively race it, that's another. Outside of that, other than going EFI, it's hard to beat that good ol' computer q-jet.
skinny z
Oct 5, 2015 06:23 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Justins86bird
Sep 27, 2015 09:43 AM
Damon
Sep 26, 2015 04:29 PM
RedLeader289
Sep 23, 2015 06:50 AM
