1989 CAMARO IROC-Z FUEL GAUGE PROBLEMS
Old Nov 11, 2007 | 03:51 AM
wicho's Avatar
Car: CAMARO IROC-Z
Engine: 350 T.P.I
I AM HAVING PROBLEMS WITH MY FUEL GAUGE IT GOES DOWN WHEN I BRAKE AND UP WHEN I ACCELERATE IT GOES UP I HAVE BEEN LOOKING AROUND BUT THEY DO NOT GIVE ME A GOOD ANSWER THEY JUST SAY ITS A PROBLEM AND THE LESS GAS THE MORE THE NEEDLE MOVES WHAT CAN I DO TO FIX THE PROBLEM IS IT THE GAUGE OR SOMETHING IN THE TANK THANKS
Old Nov 11, 2007 | 08:48 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Re: 1989 CAMARO IROC-Z FUEL GAUGE PROBLEMS
This happens in my cutlass, you need to replace the sending unit. The gas guage in my iroc doesnt work right either, its the sending unit. The sending unit is in the tank, its not that hard to replace, you could try looking for one in a boneyard but thats taking a chance that that one probably is bad too.
Old Nov 26, 2007 | 06:03 AM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
I actually just had the sender on mine replaced and it still does this, but it doesnt ever show past the full mark anymore. Pretty irritating
Old Nov 26, 2007 | 08:51 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
camaropunk, my only other guess is that its the gauge or the wiring? first id check the gauge fuse and see if thats good, then id go to the junk yard and get a new fuel gauge and see if that does anything, shouldnt cost you anything.
Old Nov 26, 2007 | 01:09 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Yeh, im working on getting one, there arent many junkyard round this way and ive tried finding one on the classifieds here, but im not paying 25 for a gauge like that. thanks for your reply
Old Nov 26, 2007 | 01:49 PM
Garconer's Avatar
Car: 1986 Camaro
Engine: LG4 305 w/ Qjet
Axle/Gears: 2.73 10-bolt
the gauge is changing because the fuel is sloshing, you probably notice the same thing going up and down hills too. If i remember right the stock tanks don't have baffles.
Old Nov 26, 2007 | 05:20 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Its moving a little much for it to be that, IMO.
Old Nov 26, 2007 | 06:34 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
? mines always done that, even in my truck, but i didnt pay any attention to it, once you stop you get the accurate reading any way so why bother replacing things?
Old Nov 26, 2007 | 06:48 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
its not to accurate, it steadys out when stopped but if i go not even a block and stop again it will be way lower than before or higher than before
Old Nov 26, 2007 | 08:24 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
I would look into a new gauge also. The sending unit is expensive from an auto store if you cant find it from a junkyard...reason being, have to buy pump also. I had a boucy one, and got a new gauge. Works fine.
Old Nov 26, 2007 | 08:26 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Originally Posted by stevenb
I would look into a new gauge also. The electric pump is expensive from an auto store if you cant find it from a junkyard. I had a boucy one, and got a new gauge. Works fine.
Yeah, I replaced the sender and it was a $280 dollar part, but since the tank had to be dropped I though it would be best to have it done along with the fuel pump. I understand that some movement is normal, but it seems a bit much for fuel to be sloshing, im still hunting for a guage
Old Nov 26, 2007 | 08:37 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
The ones in the junkyard are Junk. Chevy sells new ones for a mere $670.00 without the fuel pump. Such a deal. I think Summit sells a universal sending unit that with some creative modifications could be made to work.
That's what I did.
Old Nov 26, 2007 | 08:56 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
Used clusters are very common to find also, I have 3 sets
Old Nov 26, 2007 | 09:03 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
That's what I did.
The sending unit for mine came from a chevy dealer and it was only 280 new without the pump, same as gmpartsdirect.com,the pump costed 80 something
hook me up with a fuel gauge, if you know it works,
Old Nov 26, 2007 | 09:13 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
[QUOTE=camaropunk;3545778]The sending unit for mine came from a chevy dealer and it was only 280 new without the pump, same as gmpartsdirect.com,the pump costed 80 something
Well here in California I called at least 3 Chevy dealers and they all wanted at least $670.00. If I need another one some day I will get it shipped in.
I told them that was ridiculously high but that was what they wanted.
Old Nov 26, 2007 | 09:38 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
[quote=ringo234;3545799]
Maybe that was with install too, that would make more sense. I ended up paying $775 total on my gas tank for the sending unit, pump and tank screw hole repair and labor
Old Nov 26, 2007 | 09:39 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
no, That's just the sending unit, tubes and everything but a new pump.
http://www.gmpartsdirect.com/catalog/frameset.cfm
I checked out the link above and it has the full price of $685.00, and they mark it down to $356.00. That still a lot of money. I bought a universal one for about $40.00 and adapted it to work with my old tubing.
Old Nov 27, 2007 | 01:02 AM
1991ON20's's Avatar
Car: 91 RS, t-topped, man trans.
Engine: 350cid 350Hp crate motor
Transmission: t5 with new stock clutch and parts
Axle/Gears: 3.08 stock -RS
I have the same problem folks......and my oil gauge on my cluster does the same thing too. BUt the gas thing is really frustrating......it sucks when u gotta calculate your miles per gallon based on how many gallons you just pumped in your tank.....lol
Old Nov 27, 2007 | 04:09 AM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
hmm...I wonder why mine was only 280 then? I know he had to get it from the dealer, weird.
My oil gauge was wack for a while, but i replaced the sender for like 20 bucks and its perfect now...It does suck calculating that way. Im hoping a new gauge steadys mine out a bit
Old Nov 27, 2007 | 10:18 AM
studdmstr's Avatar
Car: 91 Z28
Engine: LB9
Transmission: auto
http://www.rockauto.com/ has the ACDelco sending unit for $311 http://gmpartsdirect.com/ has the same sending unit (19111386) for $279 + $61 shipping and handling.
Old Nov 27, 2007 | 11:45 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Wait so how else would you calculate it?
Old Nov 28, 2007 | 02:33 AM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
In my opinion, if money is an issue, buy a tank from a junkyard. Even if you gotta drive 50 miles. I bought a whole tank with everything in it for $50.
Ghettobird52
Jul 5, 2024 11:18 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
justin57
Aug 20, 2015 07:05 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
antares57
Aug 6, 2015 07:47 AM
