PLEASE SOMEONE HELP
Old Nov 12, 2007 | 10:18 AM
'86 Camaro BoSs's Avatar
Car: 1992 Camaro RS - 1971 Chevelle
Engine: 3.1L - 5.7L
Transmission: T-5 - TH350
PLEASE SOMEONE HELP
I have a 92 camaro rs with a 3.1 in it, yesterday i was driving it and out of no where i step on the clutch and it revs way up there damn near redlining it..
i'm a newbe when it comes to stuff like this, so if anyone can help please do, this car's my pride and joy i really don't wanna have somthing bad happen to it
Old Nov 12, 2007 | 11:32 AM
Engine: 3.1L - 5.7L
Re: PLEASE SOMEONE HELP
anyone?...
Old Nov 12, 2007 | 11:59 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Originally Posted by '86 Camaro BoSs
anyone?...
Since the throttle is cable operated, it's hard to say. Could be sticking or you could have a bad motor mount which is making it bind. With the hood open so you can see the engine, put some load on it both forward and reverse and see if it moves.
Old Nov 12, 2007 | 12:36 PM
Engine: 3.1L - 5.7L
Alright.. thanks, when i got the car it had alot of grease on the throttle body.. i'm guessing the guy who had it on there had it there for a reason?..
anyways thanks, i'ma go try what you said out, hope it works
al
Old Nov 12, 2007 | 12:41 PM
jv9999's Avatar
Engine: 5.7L/350
So it was probably sticking before. Usually it's dirty and the grease doesn't help. Buy a can of throttle body cleaner (no carb cleaner), take the bellows off, and clean all around the butterfly.
Old Nov 12, 2007 | 06:28 PM
Engine: 3.1L - 5.7L
i ended up wiping down the throttle lever and put a lil grease on it.. doesn't stick anymore so i'm happy, hope it lasts, and i will go get some of that cleaner. thanks again
