Harmonic balancer Need help!!!!
Old Nov 12, 2007 | 10:18 AM
1BadaGTA's Avatar
Car: 1991 Gta trans am
Engine: 383ci,trickflow alum. heads, hsr
Transmission: T-56, alumin. driveshaft
Axle/Gears: stock 7.5"/3.42
I have a 383 stroker motor internally balanced. The crank broke right before the #1 and 2 rods on the pin. Now I put up a post before and you guys told me that if it had broke there then its because I put a stock harmonic balancer on my motor. So I know that an ATI would be the way to go but I'm at a loss at what type of material and what size of the balancer to get. I can't afford to screw this thing up again so any help would greatly be appreicated.
Old Nov 12, 2007 | 11:58 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Re: Harmonic balancer Need help!!!!
Use the biggest balancer you can. I have a fluiddamper, but the ati or other brands would work also.
If it's truly internally balanced, then I wouldn't think the stock balancer is a problem unless it's worn out.
Old Nov 13, 2007 | 08:08 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
The stock balancer will not break your crank. Was your balancer part of the balanced rotating assembly? I have the same deal. 383 stroker internally balanced, stock damper. It was ALL balanced together. I've had no problems.
I'm partial to fluidampr though.
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
