having a hard time buy new stock springs for my car
Old Nov 12, 2007 | 09:14 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
wats the differents between Variable rate and reguler??? why does it matter if is manual, ac, non ac, auto?
Old Nov 12, 2007 | 09:20 PM
Damon's Avatar
Re: having a hard time buy new stock springs for my car
Major options on the car like the A/C and tranny affect the weight and weight distribution of the car which affects the rate of the springs the factory installed in the car on the assembly line. The aftermarket uses this information to try to get you the closest match possible to the original springs.
Variable rate springs have a farily normal spring rate at normal ride height but tighten up quit a bit as they are compressed becuase of the way the springs are wound. Most of the time a standard spring will work just fine although a variable rate spring really won't feel much different under normal driving and with normal loads.
Old Nov 13, 2007 | 08:11 PM
jayk2k3's Avatar
Car: 85 camaro z28
thanks, that helped alot!!
Old Nov 13, 2007 | 09:19 PM
Pat Hall's Avatar
I went with the variable rate springs out back in my 89 RS, and I've been quite pleased with them. I used factory Iroc springs in the front, and I had the Iroc rear springs in for a while. The car actually rides and sits better with the var. springs compared to the Irocs in the rear. They're nice when you're hauling stuff too. I've put some pretty heavy stuff in the hatch area (trannys, engine blocks, etc.), and the car hardly drops at all. The codes on the factory Iroc springs I've got are BZW-front, and NNL-rear.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
camaro71633
Sep 1, 2015 10:24 AM
Thirim
Aug 9, 2015 06:19 PM
mustangman65_79
Aug 9, 2015 03:00 AM
apie2546
Aug 8, 2015 07:12 AM
