Parking brake cable to frame mount
Old Nov 14, 2007 | 06:02 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
I dropped my rear to pull the tank and cannot figure out how to disconnect the parking brake cable from the frame as its rusted to hell, and I dont want to break it...
Old Nov 14, 2007 | 08:12 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Parking brake cable to frame mount
well if its rusted to hell, you will probably break it.
the retaining clips push though the cable mount bracket, there are, i think 3, little spring tabs that need to be pushed in to allow the retainer to slip back through the mount, usually you can push in one at a time with a screwdriver and work it out that way, or ive used a zip-tie a few times and they work pretty well too.
Old Nov 14, 2007 | 08:21 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Or there's a nifty little tool available at most auto parts stores.
JamesC
Old Nov 14, 2007 | 08:33 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
JamesC
yea and ive never been able to find it, and there is a diagram in the Chiltons manual on how to make your own
Old Nov 15, 2007 | 04:58 AM
JamesC's Avatar
IIRC, I purchased mine at CarQuest.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Eric-86sc
Apr 3, 2016 03:52 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
