Incr. FP for HP?!
Old Nov 15, 2007 | 05:02 PM
Mike305RS's Avatar
Incr. FP for HP?!
I was reading about increasing fuel pressure on fbody.org, and they have a chart of a dyno pull on a 350 TBI where they increased the fuel pressure on a stock engine. At 52 psi peak HP was up by like 40 and torque was similar. Is this really true? Can you gain power on a TPI motor by just giving it more pressure?
Old Nov 15, 2007 | 05:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Only if it doesn't have enough.
Old Nov 15, 2007 | 05:10 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: Incr. FP for HP?!
makes sense only if the engine is being starved for fuel. that's a big jump. It is one of the mods listed in one of the articles though.
Old Nov 15, 2007 | 05:12 PM
Mike305RS's Avatar
stock pressure for a TBI is supposed to be 12 psi and anything overthat will make extra power according to the article.
Old Nov 15, 2007 | 05:14 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
As said, only if it already doesn't have enough fuel. Otherwise, increasing the fuel pressure and the volume of fuel delivered will reduce power.
Tuning the mixture via changing the fuel pressure is a crutch for those who are unwilling or unable to burn chips.
