Help w/ what swapped engine I have and fuel injection
I just bought a 1991 RS it had a V6 but someone had pulled the sixer out and put in a V8 I was told it was an LT1 from a 1991 corvette ( don't think so) The cating numbers are 14093638 the only ifo I can find is that it is a roller engine, 5.7, made from 87-94. The guy said it had all the fuel injection stuff on it but they took it off and scrapped it
So it has a cast intake on it for a carb. I want to put it back fuel injection but I dont know what I can put back on it. Can I put TPI, TBI, or maybe an LT1 intake if possible? If anyone can tell me more about this engine and what I can put back on it I greatly appreciate it. Thanks again.
So it has a cast intake on it for a carb. I want to put it back fuel injection but I dont know what I can put back on it. Can I put TPI, TBI, or maybe an LT1 intake if possible? If anyone can tell me more about this engine and what I can put back on it I greatly appreciate it. Thanks again. Supreme Member
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Re: Help w/ what swapped engine I have and fuel injection
91 vette had a L-98
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Yes you can. What did he do with the computer?
This may be a good time to go with an aftermarket computer such as megasquirt. You could do HSR with a megasquirt, and it would work very well.
Have no idea what happened to the efi stuff they took off. What is HSR? ( sorry for the noobness) I am very familiar with MS systems, that would be the best route.
Holley Stealth Ram... Its an alternate EFI intake which ia a bit pricey. Or, you could go with a cheaper factory intake.
The reason I asked about the computer and wiring harness is because if it is all there you could use a GM ECM with a lot of wiring and repinning. However, If you have to start from scratch, migh as well upgrade while you are at it. The MS will run a Small block chevy without a problem.
Which factory intake could I use? I'm not sure what really came on my engine and what will interchange. Can I use TPI, LT1, etc? Thanks for the replies
It's a 350.
Beyond that, "which engine" is a pretty much open-ended question, given the ENDLESS interchange possibilities with the SBC.
What head castings are on it?
Yes you can put basically ANY FI on it.
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
