No power to starter? Just swapped engines
Car: 84 camaro, 92 yota 4runner
Engine: 305 lg4 out of 81 z28
Transmission: th350
Axle/Gears: Not sure believe its 3.23
OK, i just put a 305 in my 84 camaro which came with factory v6 (2.8 i believe) and later converted to 305 v8. Now i baught the car with no engine, i just put a 305 lg4 carbed engine, and wired it up, i have power inside the car, lights work and everything but, i turn the key and no power at all reaches the starter, what possible wire could i be missing? The starter doesn't tick or nothing. Any idea?
Transmission: th350
Re: No power to starter? Just swapped engines
Their is 2 that are on the same connector (i don't know how you call it the thing that slides over the bolt) and another one on a smaller bolt.
Car: 1992 RS
Engine: 01' LS1
Axle/Gears: 10 bolt auburn pro posi, 4.10 gears
is the small purple wire connected to the starter, that is the key on wire. also check to see if it is broken or chaffed. i had that problem once when my car wouldnt start.
Transmission: 4L80E/4L80E
The other is, what did you do for transmission/shifter? There's a thing called the neutral safety switch, if you fiddled around inside the car that may have been neglected.
Car: 84 Z28
Engine: 383
Axle/Gears: 7.5 3.73
I agree, u must check this, I put a B&M shifter in my 84 and it wouldnt start at first. You have to do some wiring if you changed the shifter out or no go!!
Transmission: th350
its cool guys, after frigging around with it for 2 days i have given up and wired it to a push start button, thanks for the help any ways, just couldn't find the problem.
