Fuel Injector Removal
Old Nov 20, 2007 | 12:26 PM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
Im attempting to remove the fuel rail on my LT1 on way to tearing down the motor and i just cant seem to dislodge the injectors out of the manifold.
Is there any advice or tricks to ease in this?? Ive pulled and wiggled and pulled some more and i just cant manage to get them out.
Im about to just hook the engine hoist up to the fuel rails and just jack it up lol but i dont want to break anything.
Thanks for any help!
Old Nov 20, 2007 | 12:31 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Fuel Injector Removal
I'm not sure about an LT1, but my original injectors on my L98 were stuck pretty good...
If I recall, I took a breaker-bar and stuck it underneath the fuel rail (from the side) and GENTLY eased it up. Be patient and make sure you are really careful - you don't want to damage the rails or anything else!
Hope this helps!
Old Nov 20, 2007 | 09:16 PM
BCdawg57's Avatar
thanks i will try a pry bar, but i dont think it is as easy to get one under the rails on an lt1 as it is on my lb9. But thanks for the input!
bryan623
Mar 22, 2021 06:43 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
3rdgenparts
Aug 8, 2015 07:09 PM
