engine malfuntion
Old Nov 22, 2007 | 05:16 PM
redmaro91's Avatar
engine malfuntion
My 1991 Camaro z-28 will not run right when i am going down the road. It seems that when my rpms get high enough the engine starts losing power and the rpms slowly drop until i let of the gas. Then I have to put it in neutral and let the rpms go down until it is idling. Then I shift into drive and it acts normal until I get into high rpms. The longer it keeps running the faster it acts up. I have changed the fuel pump, fuel filter, fuel pressure regulator, oil pressure regulator, oil, oil filter, MAP sensor, positioning sensor, Eg air valve, rotar button, distributor cap, spark plugs(wires),pickup coil, the sensor under the distributor cap, oxygen sensor, and the computer, and it still has not worked yet. Is there anything I could possibly do.
Old Nov 22, 2007 | 07:57 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
Re: engine malfuntion
catalytic converter.... same symptoms i had on my old 89 iroc, put a "test pipe" in its place, and it felt like a brand new car, and sounded better too. i recomend replacing the cat with a high flow cat. you can get under your car and hit the cat with your palm hard, and if its rattling, 100% replace it. but if it doesn't rattle, it could still be bad.
Old Nov 22, 2007 | 08:28 PM
redmaro91's Avatar
thanks for the tip. I will try it out
Old Nov 23, 2007 | 08:31 PM
redmaro91's Avatar
it still didn't work. I cut the cats out and put in straight pipe. I put it on a computer and it says that my exhaust is rich. also it reads that the temp is -34 degrees.
Old Nov 23, 2007 | 10:09 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
Replace the coolant temp sensor. What about any codes? By high RPM what number do you mean? Have you taken a look at your spark plugs?
Old Jan 23, 2008 | 11:21 AM
redmaro91's Avatar
would it have anything to do with my computer? It happens around 2grand or so
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
