need some opions about why my car idles so high
Old Nov 23, 2007 | 09:02 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
just got my car back on the road, its idles around 1200-1500rpm. i just put a manual trans with the stock auto ecm. i havent drove the car in about 1 year, so im not sure if it the ecm causeing this because the manual trans (used to be automatic), throttle body spring or throttle cable. if i play with the throttle body 4 a bit it will idle at 800rpm which is move reasonable.
Old Nov 23, 2007 | 10:09 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: need some opions about why my car idles so high
throttle body could need to be cleaned. also since the linkage is missing the resistance of the tv cable the throttle body could need a different return spring(assuming a TBI). i would start by cleaning it real good with some throttle body cleaner to get all the dirt a grime off. after that, see if your throttle linkage returns to hte throttle stop when you let off the gas.
Old Nov 24, 2007 | 12:29 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Have you put in the correct ECM chip for a manual trans, or reprogrammed for manual trans?
Old Nov 24, 2007 | 05:49 AM
jayk2k3's Avatar
Car: 85 camaro z28
no
Old Nov 24, 2007 | 08:46 PM
jayk2k3's Avatar
Car: 85 camaro z28
im goin to put a new cable on. do they still make it ?? can't find it
Old Nov 24, 2007 | 09:23 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
A used one will work just as well.
Lokar has new ones. http://www.lokar.com/interior_pages/tc_kd.htm
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
