cant rev past 4500
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
cant rev past 4500
I cant rev the car past 4500 in any gear, replaced distributor within 400 miles, coil within 20 miles, spark plug and wires within 50 miles........ideas? i had this on electronics section too but wasnt getting much attention
Car: 92 Camaro
Axle/Gears: S60 373
Re: cant rev past 4500
well i drove the car last night to put sme gas in it and just a few minutes ago i went outside to double check the ground wire...it was a little loose so i tightened it up and went to start it to see if that was the cause of it not revving to 6k. Well now it wont start at all.....and the inspection runs out friday...
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
well check all the electrical ignition related stuff to make sure your getting spark.
Car: 92 Camaro
Axle/Gears: S60 373
well.....i couldnt start the car....replaced ignition module and now it starts....but its sluggish as hell, major power loss...major ignition problems always with this car
......good thing im putting the thing in storage otherwise id put a shotgun to the engine
......good thing im putting the thing in storage otherwise id put a shotgun to the engine Thread
RedLeader289
May 28, 2019 01:47 PM
gixxer92
May 18, 2017 11:20 AM
darwinprice
17
Oct 11, 2015 11:51 PM
