Stock LG4 305 from an 83 Camaro, cam recommendations please
I have a stock 305 in my 83 Camaro with a 5 speed. I have a new intake with a new type carb, a Carter AFB, as we got tired of the old quada-jet. I have headers and that's about it. What would be a good improvement in performance with some street manners as for a cam? Is there much involved with going with a roller hyd cam? With a hotter cam, when will I have to replace the valve springs to avoid coil binding? Which springs would be good in my application? Thanks guys.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: Stock LG4 305 from an 83 Camaro, cam recommendations please
look at the summit brand line of cams with duration in the 204/214 or 214/224 range. the comp 980 springs will handle these fine (basically a quality stock replacement) and i would recommend new springs with the cam swap, regardless of lift/duration on the cam...those valve springs you have right now are 24 years old.
Actually I bought a rebuilt 305 from AutoZone 7 years ago and swapped it out. So that would make them maybe 7 years old. But springs are cheap and I'll replace them. Thanks for the reply.
Transmission: 4L80E/4L80E
Most likely they put the old springs back on the heads when they put it back together.
'83's are 25 years old now. . .
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
