New intake installed, car isn't running right
Old Nov 27, 2007 | 06:06 PM
xGR1Mx's Avatar
Sup guys. I just moved to this thread 'cause I have a different problem now.. the car was kinda jumpy.. and it seemed like smoke was coming out of a fitting in the back of the manifold? It screws in and then has a little pipe that sticks out, im guessing a hose is to run to it. Truth is, I didnt pay enough attention with some of the hoses.. Also, theres a hose that branches out from the two coolant hoses that run over the passenger valve cover.. I dont know where that goes. Here are some other smaller hoses im not sure about..
That's an old picture.. When I started the car, it was jumpy, and i was hearing "pop-po-popop" coming from my exhaust, so I shut the car off. I also have to replace the vacuum line that broke off the back of my carb, if that could be adding to the problem..
Any ideas will be much appreciated, I want my beast back!
Thanks everyone.
Old Nov 27, 2007 | 06:11 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: New intake installed, car isn't running right
Along with the vac problem, it sounds like a timing issue to me.
Old Nov 29, 2007 | 07:21 PM
ProjectIrocZ28's Avatar
Car: 88 Monte Carlo
Axle/Gears: Really Tall ones. Probably 2.73's
your 180° or maybe 90° off your ignition timing. set piston #1 to compression stroke, tdc and check your rotor. if its not pointing at #1, you're off.
specialized
Jun 18, 2022 09:26 AM
midge54
Dec 27, 2019 04:14 PM
86IROC112
Aug 17, 2015 02:00 PM
bryan623
Aug 10, 2015 11:33 AM
mustangman65_79
Aug 8, 2015 12:07 PM
