89 TA won't start.. Could be fuel pump?
Old Dec 11, 2007 | 11:08 AM
slipsixx's Avatar
Car: 89 Trans Am
Engine: 305HO TPI
Yesterday I tried starting my 89 Trans Am, and had no problems started right up. I drove it about six blocks from my house, and it started to bog, then just died. Now it won't start. I noticed howover, when I turn the key to the ON position, I don't hear that super cool electronic fuel pump making any noise like it usually does.. soo..
Where can I find a wiring diagram for the ignition system?
[EDIT]
Found the FP relay, replaced it, not the problem. I still don't hear the pump kicking on when I turn the key.
Old Dec 11, 2007 | 12:32 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: 89 TA won't start.. Could be fuel pump?
[EDIT]
You might want to check the fuel pump fuse. It's next to the battery in my '87. Autozone.com has some wiring diagrams online, you might try there.
Old Dec 11, 2007 | 10:19 PM
L98 Uh_Oh's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7L TPI L-98, Headers, Flowmaster
Transmission: 700R4 w/shift kit
Axle/Gears: Stock, I think...
I would check that FP fuse, capped next to battery. I think its an orange and red wire? Is there a FP fuse under dash?
If not the fuse(s), try to manually run FP. Run 12v jumper wire from fuse box to Pin G of ALDL. When key is in "on" position, FP will run continuously.
Old Dec 13, 2007 | 04:14 AM
IROZINCO's Avatar
TPI also has a fuel pump relay. It's mounted on the drivers side of the firewall along with 3 other relays. That does usually throw a computer code, but not always.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
