Belt System
Old Dec 11, 2007 | 10:43 PM
afida15's Avatar
Belt System
where can you buy a V Belt pulley set up. like all the pulleys and bolts. i had a serpentine on the motor that was in my car but i threw most of the parts away. and all serpentine aftermarket setups are to exspensive
Old Dec 11, 2007 | 10:52 PM
dayton's Z's Avatar
Car: 85z-28
Engine: gm goodwrench 350
Transmission: t-5
Axle/Gears: stock, 3.08 one wheel peel!
Re: Belt System
local junk yard, or find someone going from v belt to serpentine system, good luck!
Old Dec 11, 2007 | 10:56 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: Belt System
same with a serpentine system too. JY will have them. Remember if you are using a water pump for a serpentine belt it is reverse rotation. aka not for use with V belt.
Old Dec 12, 2007 | 08:39 AM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
Re: Belt System
Stay with the serpentine set up. Search for post by amarano12 he was selling some for $120.
Galaxie500XL
Feb 1, 2020 04:53 AM
codeysabatini
Nov 10, 2015 04:07 PM
iroczguy86
Sep 13, 2015 02:22 PM
MORREALE5
Sep 10, 2015 08:58 AM
buckshot63
Interior Parts Wanted
Sep 3, 2015 08:10 AM
