TPS ?'s
Old Dec 18, 2007 | 12:09 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
TPS ?'s
I ran over all of my work i've done, redid my spark plugs, checked my wires for the 10 millionth time, timed it to 6 btdc like alldata says following their directions to the t, and i'm still hitting a slight jerk, not as severe, when i hit 50. HOw long does it take to check and how do i do it? Also how much for a new one and what do i need to install it>?
Old Dec 18, 2007 | 07:55 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: TPS ?'s
https://www.thirdgen.org/tpimod2
The cost varies depending on where you purchase one at... Look at autozone.com
Why didn't you ask this in your other post???
Old Dec 18, 2007 | 01:25 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TPS ?'s
The stock ignition timing for an '89 TBI is 0 degrees, w/the EST connector open.
RBob.
Old Dec 18, 2007 | 06:40 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: TPS ?'s
well, it runs like complete crap at 0, so 6 seems to be working for me lol
Old Dec 18, 2007 | 07:25 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TPS ?'s
That may be a sign that something else is wrong. Is the engine stock? If so, then it should run OK with stock timing.
RBob.
Old Dec 18, 2007 | 11:00 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: TPS ?'s
to be honest i coudlnt say, i keep finding new things on this car, telling me that theres no way in hell this engine is 20 years old, im slowly piecin the puzzle together though
92camaro350cci
Oct 14, 2015 09:29 AM
Fred SS
Oct 12, 2015 11:27 AM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
