tbi to tpi question
Old Dec 18, 2007 | 11:48 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
tbi to tpi question
correct me if im wrong but the tpi stock, comes on an l98 enigne, if i do a top end swap to make my tbi l03 a tpi, that doesnt make it an l98 does it? Im just not seeing the line between the 2 engines except for the tpi setup anyone wanna explain it? Are the parts you order different when going for plugs and wires or just pertaining to the things i swap?
Old Dec 19, 2007 | 12:12 AM
lonman89's Avatar
Car: 1985 chevy camaro IROC-Z
Engine: 5.7 litre 350 4 bolt main
Transmission: 700r w/B&M shift kit
Axle/Gears: 10 bolt w/3:42 gears
Re: tbi to tpi question
the tpi setup was used on both 305(LB9) and 350(L98),85and 86 had the 305 tpi only,87-up had the option of 305 or 350 tpi,i like the tpi setup alot better than the tbi,my iroc had the LB9 tpi motor in it and it was nice but i swapped in a 350 4bolt that was carb'd and havent been disappointed,id use the tpi setup opposed to the tbi setup but thats just me
Old Dec 19, 2007 | 12:16 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
TPI also had different heads, a better camshaft, better exhaust manifolds, and better exhaust. But the spark plugs and wires should be the same or very similar.
Old Dec 19, 2007 | 12:24 AM
lonman89's Avatar
Old Dec 19, 2007 | 11:17 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
so would i be better off getting a tpi motor? or takin mine and just doing a top end swap and maybe some heads and a cam? im not looking for mass power, i just like tpi better, for its looks and i dont like tbi its too outdated for me
Old Dec 19, 2007 | 11:41 PM
Kevin91Z's Avatar
It depends on how much money you have. A TBI to TPI swap with just the intake, fuel pump, LT1 camshaft, and computer swap could cost $1000+. A 350 TPI swap could cost $4000+.
Old Dec 20, 2007 | 08:03 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
on one hand i ust want to do it, and rid myself of tbi lol, but on the other, i want it done right so i think im just gonna pick up an l98 thats kinda old and tear it down and rebuild a new one, i've got to talk to a buddy of mine who just had his engine redone and see where he got it, i dont care if it takes me years to build i want this thing right
MustangBeater20
Oct 29, 2022 09:20 PM
evilstuie
Jan 9, 2020 08:29 PM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
