question - where to attach a hoist
Old Dec 19, 2007 | 11:20 AM
AZZ28's Avatar
Car: 1990 IROC
Engine: l98
I have an L98 that I need to support while I swap out the k-member. Where do you guys like to attach the hoist on the L98 motor?
Old Dec 20, 2007 | 11:07 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: question - where to attach a hoist
Intake manifold bolts
Old Dec 20, 2007 | 02:07 PM
AZZ28's Avatar
Car: 1990 IROC
Engine: l98
Thanks for the reply. I guess I will look and see what kind of brackets I have to work with.
Old Dec 21, 2007 | 05:03 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
There should be a bracket mounted to the rear pass head. On the front you can use an intake manifold bolt. Or for the front you can do what I did. Remove the alternator and run a bolt through the alt/ps pump bracket where the alternator attaches (long through bolt).
dustint209
Sep 9, 2015 08:09 AM
Trickskier
Aug 29, 2015 01:12 PM
Hello, Michael
Aug 20, 2015 03:19 PM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
