Trouble with my coolant temp sensor
Old Dec 25, 2007 | 04:46 PM
Joeboy's Avatar
Hey guys, Im having trouble getting my coolant temp sensor off of my 85 Z28 TPI 305. I took the alternator off and the bracket so I have a good look at it. But I cant seem to find a way to get it off of there. Im trying to slip a 3/4 box wrench around it but it wont seem to do the job. The new temp sensor is 3/4 so I assume the old one is to. Any suggestions or advice would be appreciated. Thanks a lot.
Old Dec 25, 2007 | 04:55 PM
deadtrend1's Avatar
Re: Trouble with my coolant temp sensor
Don't assume, make sure you have the correct size so you don't round off the hex of the sensor. Maybe someone used loctite previously to seal it in there. Should be too much of a pain since the TPI manifold is aluminum.
Old Dec 25, 2007 | 05:01 PM
Joeboy's Avatar
Theres another sensor directly left of it and a coolant line right above it. So Im having trouble getting at it.
Old Dec 25, 2007 | 07:30 PM
RSTurbo2800's Avatar
Car: 1989 Camaro RS
Engine: 2.8 MPI
Axle/Gears: 10 Bolt 3.73:1
Here's my solution to this Problem. Get one of the old style Crafstman 3/4 Combination Wrenches, Clamp the Open-End in a Vise, Heat the Shank of the wrench just above the Vise until it has a good glow. Slowly bend the wrench to 90 Degrees, then Oil quench it in 85W/90 oil (make sure you are away from anything else that's flammable 'cause you're gonna get a fireball when it hits the oil). Once cooled, hold the box end in your hand with the edge of the box even with the Knuckle of your little finger and mark the wrench 1" back from where your Index Knuckle touches the shank of the wrench. Clamp in Vise at Mark and heat wrench again, slowly bending it the opposite direction.
Oil Quench again and allow it to completely cool before using.
The 4" Offset is Perfect for Getting around GM Intake BracketsAnd removing Intake Mounted sensors. Oil quenching retains the tool hardness. I Made Mine because of a GMC Van that had a bad temp sensor.
Old Dec 25, 2007 | 07:58 PM
Joeboy's Avatar
It looks like Ill have to remove that sensor to the left of it. Does anyone know what that is and if coolant is going to coming out of it. Looks like its about a one inch fitting.
Old Dec 25, 2007 | 09:01 PM
deadtrend1's Avatar
Its a sensor for the cold start iinjector f i remember correctly. My car has been in storage so I can't go look at it. sorry..
Old Dec 25, 2007 | 09:03 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
can you use a deepwell socket?just a thought,jimmy
Old Dec 25, 2007 | 10:00 PM
Joeboy's Avatar
Yeah I dont have one Im gonna try that tommorow Itll have to be just the right length or it wont get in there because of the water pump pulley.
Old Dec 26, 2007 | 04:28 PM
Joeboy's Avatar
got it all done. Had to take out the cold start sensor. Everything is all buttoned up and the Check Engine light is off. SMOG here I come. wish me luck.
Old Dec 27, 2007 | 07:34 AM
1fastam's Avatar
Car: 1991 transam
Axle/Gears: 4:10
good luck!!!!!!!!!
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
corey8084
Sep 17, 2015 02:56 PM
m00n420
Sep 11, 2015 02:39 PM
FormulasOnly
Sep 10, 2015 09:07 PM
