600 or 750
Car: 85 Pontiac Trans Am
Engine: wouldnt you lilke to know??
Transmission: TH350 Built to the hilt
Axle/Gears: 4:10 Gears Moser Axle Auburn Posi
600 or 750
hey i just bought a goodwrench 350 with 260 horse should i throw my 600 off my 305 on it or a 750 that ive had sittin round for a while??? i do have a dual plane wieand intake it
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 600 or 750
Carb calculators give a minimum requirement. Larger carbs give a bit more power and a flatter power curve.
As for mileage, not all carbs are the same. You can use 3 different model 750's and get 3 different performance and mileage results.
Re: 600 or 750
Try 'em both, see which you like better. A rarely use carbs smaller than 750 CFM on anything 350ci or larger, especially with a dual plane (since any given cylinder only "sees" half the carb). You didn't mention if either of those carbs is a double-pumper. If they're both vacuum secondary it's pretty much impossible to over-carburate.
RedLeader289
May 28, 2019 01:47 PM
[Sold] Quick fuel 750 cfm
mackjar66
Sep 14, 2015 01:17 PM
