Sea Foam= code 32 & 33
Old Dec 28, 2007 | 11:58 PM
Oscar's Avatar
This is kind of a continuation from my "FAILED SMOG" post in TPI and Tech Geneal Engine forums.
Tech General Engine forum
https://www.thirdgen.org/forums/tech...ew-engine.html
and
TPI forum
https://www.thirdgen.org/forums/tpi/...ew-engine.html
So, in attempting to get my car to pass smog, I reduced my fuel pressure from 48 psi back down to stock 42 psi. Then I went through 2 cans of Seafoam, and used the G2P "guranteed to pass" with a full tank of gas. Two days ago after trying to use up the tank so I can refill to pass smog, I started getting codes 32 and 33. (I did read the tech article "Lowdown on Code 32"). Prior to the Sea Foam, I wasn't getting any codes. I did notice the engine light comes on at frwy speeds approx. 70 mph. My EGR is new and was checked out as being ok last week. Also the solenoid is apparrently working. So as the article mentions, is it possible that carbon was losened up and now restricting vacumm somewhere? Why the code 33 as well at the same time code 32 was triggered? How should I proceed in checking for these two codes given the information I have provided.
thanks!
Old Mar 26, 2008 | 07:28 AM
NEWMAN1786's Avatar
Car: 91 z28, 92 rs
Engine: 350 zz4, 305 tbi :(
Re: Sea Foam= code 32 & 33
sorry i know this doesnt help you but what state are you from and as far as smog laws what about your headers i also have slp headers but i havent put them on yet because they delete the a.i.r. system did you notice major hp gains with them how do they sound? do you have any pics of your car i have some of the same mods and you have and are planning on doing some of the other ones you have done right now im also getting error code 33 hopefully its just a bad maf sensor
Old Mar 26, 2008 | 11:12 AM
Oscar's Avatar
I'm in California. My SLP's have the A.I.R. tubes so they are both legal and have the carb #. I definetly can feel the difference in power gains from doing my mods. The exhaust sounds great to me. But I think that's more from the cat back.
To make a really long story short, my car passed smog a couple months ago. The main culprit was my O2 sensor. It was sending a false signal to the ECM telling it that the car was running really lean. So the ECM was richening the fuel mixture by alot. When the car finally passed, it did so with low double digits which is far below the average.
My car is not a daily driver but here are is a picture of mine. I have to retake pictures of my car though because I added stainless steel tips that peek out know. Also need to retake engine bay pictures.
https://www.thirdgen.org/forums/atta...51modsmall.jpg
Old Mar 26, 2008 | 11:23 AM
NEWMAN1786's Avatar
Car: 91 z28, 92 rs
i guess i need to find some headers with the air tubes so i dont have to worry about that problem i have the flomaster cat back system on a zz4 engine it seems like every time i try to do something to the car something else goes wrong with it im geting an error 33 i changes the map sensor but its even worse now when i start it up it idles bad and cuts off as soon as i press the gas i have slp runners but when i put them on the car idled all the way up like my foot was on the gas so i put the orginal runners back drove it for a couple of days and now i have the 33 code
Old Mar 26, 2008 | 02:54 PM
Oscar's Avatar
As far I've seen Dyno Don in the other forums, here SoCal make the 1 3/4 headers. I've read that SLP no longer makes headers. Visit the Exhaust forum for more info.
Sorry to here about your code 33 troubles, maybe visit the Tech / Engine forums to see if someone there can help you.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
