Suggestions???
Old Jan 5, 2008 | 01:14 PM
83-84z28's Avatar
Car: 1983 z28
Engine: '73 4-bolt 350
Transmission: t5
Axle/Gears: 3.42 with auburn and 28 spline axle
Suggestions???
In preperation for my new Holley carb to replace the Edelbrock (going with a 82651 holley street hp), I just got a new set of Fel-Pro 1206 intake gaskets and am going to gasket match the intake and heads.Any ideas on the process and should I also smooth out or port the top of the intake where the carb sits? Also as a few friends have told me to get a different cam for my combo anyone have any suggestions for a cam and lifter swap? I only drive it occasionally and am interested in maybe going to the track every once ina while and not make an embarassment of myself. It currently has 9.6:1 c.r. and all the other things listed in my sig. Any help-suggestions would be appreciatedThanks!
Old Jan 6, 2008 | 07:16 PM
83-84z28's Avatar
Car: 1983 z28
Transmission: t5
Re: Suggestions???
Anyone?
Old Jan 6, 2008 | 10:37 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Suggestions???
I think your current cam is pretty good, I wouldn't change it.
Port matching doesn't do a whole lot, but focus on the top of intake port wall. Bring that as high as you can.
Some people cut the divider wall down a bit on their dual plane intakes. Something to think about, i'm not entirely sure the point of it though.
Otherwise i'd leave the carb area alone.
Old Jan 7, 2008 | 12:12 AM
83-84z28's Avatar
Car: 1983 z28
Transmission: t5
Re: Suggestions???
great ideas thanks! I'll try to follow your advise on the upper part of the port and probably leave the carb area untouched BTW just picked up the Feb '08 Hot Rod and in it theres an article on porting intake manifolds. Though much more than anything i can aspire to but he did get up to 13 hp. more versus as cast. Of course i'm going to go simple and do as suggested.
Old Jan 7, 2008 | 05:42 AM
83-84z28's Avatar
Car: 1983 z28
Transmission: t5
Re: Suggestions???
forgot to ask do you mean the top of the port on the head or the manifold? Sorry if i sound blonde, just dont want to do the wrong thing
darwinprice
17
Oct 11, 2015 11:51 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
gord327
Oct 3, 2015 01:25 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
R13_Braz
Sep 18, 2015 05:00 PM
