My car has trouble moving!!!
Old Jan 5, 2008 | 09:34 PM
jefro89's Avatar
Okay heres the thing, I have a 1989 camaro RS V6 and i recently replaced the radiator, and after that i would start it up and put it ib gear but it wouldnt go anywhere all it would do is rev way up. So finally i thought to check the trans fluid and of course it was bone dry so i put some in and now it moves but I still have to rev it really high for it to go anywhere.
And I was wondering if anyone could tell me where my thermostat is because my temp gauge is all messed up it says my car is VERY hott but the engine is only warm!
Old Jan 5, 2008 | 09:37 PM
creepingdeath's Avatar
Car: 84 Z28
Engine: carb 305
Re: My car has trouble moving!!!
If you can't find your thermostat you should probably bring your car to a mechanic..
Old Jan 5, 2008 | 09:40 PM
jefro89's Avatar
well im pretty sure i know where its at and i looked but its not there so i dont know if theres just not one in there or if im looking in the wrong spot
Old Jan 5, 2008 | 09:48 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
You should just tell him. After all isnt this a place where people come to learn things about their car? I'm sorry I can't tell you (I don't know either)but it just ticks me off when people say something like that.
Old Jan 5, 2008 | 10:09 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
I find that hard to believe unless you're a real NEWCOMER to the SBC(small block chevrolet) world. However, follow the hose that comes off the top of the radiator to the front of the intake manifold...you'll see whats called the thermostat housing(two bolts), remove bolts, lift up the housing and you'll find the thermostat.
AkDrifted
Aug 17, 2015 07:45 PM
novaderrik
Aug 10, 2015 12:44 PM
hokis
Aug 9, 2015 03:57 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
